15 years agoNios II Ethernet Standard Design Example
I just built and compiled the Nios II Ethernet Standard Design Example with no problems, and successfully programmed it on my Cyclone III Nios II NEEK development kit. I did a quick SW check by...
15 years agoAh ha! The error I was getting was:
web_server.c:346: error: 'led_pio_base' undeclared (first use in this function)The example Qsys design implements two Qsys submodules, one of which contains the LED_PIO component. I checked to see if it was defined in the system.h file as you suggested, and found that it had the name "PERIPHERAL_SUBSYSTEM_LED_PIO_BASE". I changed the web_server.c file to use this name instead of "LED_PIO_BASE" and it compiled and ran correctly. Thanks for your help and quick reply to my plea for help. now, how do we get this information to altera so they can make the correction to the example design?
