15 years agoNios II Ethernet Standard Design Example
I just built and compiled the Nios II Ethernet Standard Design Example with no problems, and successfully programmed it on my Cyclone III Nios II NEEK development kit. I did a quick SW check by...
15 years agoIt's because you have to declare in your sopc a component name LED_PIO that must be of the type GPIO OUTPUT. If you dont want this you can remove all the references to LED_PIO in the sourc codes of the webserver
