12 years agoNios II erratic performance, will not connect to target system
Hello, I have been working almost a year with the DBC5CEFA7 Board and I have several inconsistency problems with the Nios II processors. I am using to read and write information to other VHDL modules...
11 years ago --- Quote Start --- Were you able to resolve this? ... I keep getting the "connected system id: not found" error. --- Quote End --- Hi yes, i managed to solve the problem. I learnt how to use SignalTap and then i realized that my system was not cofigured correctly, i don´t remember anymore what was the error. You should try to use it and begin with the clock and reset signals, if they are not correctly sent to the nios it will never work.
