12 years agoNios II erratic performance, will not connect to target system
Hello, I have been working almost a year with the DBC5CEFA7 Board and I have several inconsistency problems with the Nios II processors. I am using to read and write information to other VHDL modules...
11 years agoWere you able to resolve this? I have the same situation. I can build a new .sof, download it and eclipse will find the correct id... but then if I recompile the exact same project (not changing anything) then I keep getting the "connected system id: not found" error. This is really frustrating and time consuming. Any insight into possible causes or solutions would be greatly appreciated.
