16 years agoNios II Embedded Evaluation Kit with USB camera
is there a posibility of connecting a USB camera this kit? Is there any project that capture image data? C1 Reply
If you mean to the USB port of the kit then the answer is no. That port is a USB end point (or whatever they are called in "USB speak") so it wouldn't be possible for the FPGA to request data from it. Also it is configured to be a programming cable circuit so it's basically a USB-Blaster and nothing more. There are USB PHY add-in cards that you could use if they hook up over HSMC by removing the LCD card, I have only seen ones that use the Santa Cruz connector form factor but I haven't been looking at USB stuff in years so that has probably changed.
