16 years agoNios II Embedded Design Suite and Processor
could someode tell me why i could need the Nios II Embedded Design Suite for ein Video application, and what about Nios II Embedded Processor? Thanks
16 years ago --- Quote Start --- if you are using VIP Suite, the blocks can have run-time control of parameters. these parameters are controlled over an Avalon-MemoryMapped bus. you can write an HDL state machine to load the registers over Avalon-MM, or you could use a Nios II processor. --- Quote End --- I am new with the Nios II processor. I intend to use it to implement it in a SOPC . It's for a controller in power electronic applications. I would like to know why the Nios II could be a good option over other soft-cores for power electronics ? Thanks
