Rainwang
Contributor
4 years agoNios II EDS installation issue on Quartus V21.1
I have installed the Quartus 21.1 and manually installed the Nios II EDS per document Intel FPGA Software Installation and Licensing, but i can't create new project from template, pls see the attache...
- 4 years ago
Do you have any further update or Should I consider that case to be closed?
Sheng
Rainwang
Contributor
4 years agoThe following solution helped me:
Created a new environment variable in Windows:
Value: SOPC_KIT_NIOS2/p
After restarting Eclipse and Quartus it worked.
ShengN_altera
4 years agoHi,
Looks like the problem is solved by you own.
Sheng
