16 years agoNIOS II EDS compiliation program size
Hi all, i am compiling a Program using NIOSII EDS 10.0SP1. My (onchip-)Memory has a size of 49152Bytes. The Compiler tells me: Info: (cas02_PGM1.elf) 44 KBytes program size (code + initial...
16 years agoHi,
yes i am using the onchip-memory as the program-memory for my NIOS. When i modify the code (add some functions) the Complier displays the following: Info: (cas02_PGM1.elf) 46 KBytes program size (code + initialized data). Info: 2184 Bytes free for stack + heap. That is what i expected (48k). Any change in my code changes the free bytes (thats o.k), but sometimes free+used bytes are not the same as the size of my memory. I can reproduce this behaviour with other programs... Paddy
