13 years agoNIOS II Eclipse can't read ID and TimeStamp
When setting up the Run Configuration, under Target Connection, I can see the USB-Blaster but the IDE can not read the expected ID and system Timestamp. The FPGA was programmed to 100%. Is that re...
13 years agoI have faced to this problem (can't read ID and timestamp although "system-console" can). to workaround, i close and restart the nios eclipse.
Obviously, It can also occurs when the Hardware (.sof) (precisely the Qsys generated) doesn't match the BSP (in Nios Eclipse project)
