13 years agoNIOS II Eclipse can't read ID and TimeStamp
When setting up the Run Configuration, under Target Connection, I can see the USB-Blaster but the IDE can not read the expected ID and system Timestamp. The FPGA was programmed to 100%. Is that re...
13 years agocan you use signaltap and check the clock and reset signals to the CPU? A very common mistake is to use the wrong polarity on the reset signal. Usually a QSys/SOPC builder reset input is active low (when it is called reset_n) while most IPs use a active high reset.
