13 years agoNIOS II Eclipse can't read ID and TimeStamp
When setting up the Run Configuration, under Target Connection, I can see the USB-Blaster but the IDE can not read the expected ID and system Timestamp. The FPGA was programmed to 100%. Is that re...
13 years agoIf you are using a time limited .sof, you should have a window opening just after you configured the FPGA, saying that you are running in Opencore evaluation mode. Do you close that window? If you do then the CPU stops working. You need to keep that window open when you use the IDE.
