16 years agoNIOS II dubug error
Hi all: When I click on "run as NIOS II hardware", the process stops and the consloe window appears the information as follows: You have more than one JTAG cable available so you mus...
16 years agoThere are a couple of ways to do this. You can select [Hardware Setup...] from the Quartus II Programmer. Once in the Hardware Setup dialog, highlight the cable to remove and click [Remove Hardware].
-or- From the Nios II SDK Shell, you can run: jtagconfig This will show what cables are available. You may want to remove the 2nd cable with this command: jtagconfig --remove 2 -edj
