16 years agoNIOS II dubug error
Hi all: When I click on "run as NIOS II hardware", the process stops and the consloe window appears the information as follows: You have more than one JTAG cable available so you mus...
16 years agoThank you so much! You are right. I have two Altera Blaster cables actually! I changed the settings last time, but I don't know where I had changed the settings now.So do you know where I could change the cable setting?
