16 years agoNIOS II dubug error
Hi all: When I click on "run as NIOS II hardware", the process stops and the consloe window appears the information as follows: You have more than one JTAG cable available so you mus...
16 years agoWell ... do you in fact have two Altera Blaster cables? If so, then you probably ought to follow the instructions given and edit the Debug or Run configuration so as to add the --cable options to the launch.
If you don't have two Blaster cables connected, I would suspect some other USB peripheral that also uses the FTDI USB chipset is present on the system and messing things up. Jake
