21 years ago
NIOS II DMA HAL
Anybody use the DMA HAL driver?
I need correct example for stream device and memory.
I want receive from steram device through DMA(using HAL) and save stream data to memory.
I have written worked code using DMA registers, but can't get right result for HAL.
Studying of sourcel codes for HAL DMA indirectly specifies a mistake in HAL library, but I am not confident it.
    I check idea with change the ALT_DMA_RX_STREAM_ON to ALT_DMA_TX_STREAM_ON in the IOCTL request.
    All init steps passed correctly. But program haalted after call "alt_dma_rxchan_prepare".
    Program passes to an infinite cycle of ISR from DMA (i set break point in alt_avalon_dma_irq function).
    The first time ISR ocurred before programm return form alt_dma_rxchan_prepare, after write to DMA_CONTROL register.
    In ISR apdated DMA slot information, and programm go to infinite ISR cycle, however request for data send to SHARC processor not sended and no data was sended to SPI.
    This is HAL bug?
    I can't see any obvious source of this problem. However I do notice that in your test code you use a transfer size of DMA_BUFF_SIZE*2 and in your HAL example you use a size of 1024. I don't know what value you have set for DMA_BUFF_BYTESIZE, but could it be that you have a memory overwrite here?
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    However I do notice that in your test code you use a transfer size of DMA_BUFF_SIZE*2 and in your HAL example you use a size of 1024.[/b]
    --- Quote End ---
    Excuse me. In my case it is bad style.
    For dirrect DMA registers acsess:
    For DMA_BUFF_SIZE*2:# define DMA_BUFF_SIZE (1024*1024+1) // transaction word 16-bit
    alt_u16 *buffer=NULL;
    buffer = (alt_u16 *)memalign(2, DMA_BUFF_SIZE*2); // allocate memory for DMA_BUFF_SIZE 16-bit words
    IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_SPI_REC_BASE, DMA_BUFF_SIZE*2);
    For HAL example:# define DMA_BUFF_BYTESIZE 1024
    alt_u16 buffer[DMA_BUFF_BYTESIZE];
    alt_dma_rxchan_prepare (rx, &buffer[0], 1024, NULL, NULL);
    Memory overwritenn cann&#39;t occur, becouse:
    1. In prepare call I request less bytes then allocated for buffer.
    2. DMA HAL passed to infinite ISR cycle before call of function Send2Sharc(0xA5); This function initiate the transfer process.
    I have just tried to run your code on the Stratix 1S10ES full reference design (with RX_STREAM changed to TX_STREAM), and it seems to work fine. The important change I made is that I removed all the references to the SPI, and instead directed the DMA to read from a location in memory.
    It looks like in your case you have some configuration problem relating to the SPI. From here it&#39;s difficult to determine the source of the problem beyond that...
    I have not read carefully the previous posts(I will do that later). I have a problem which is simlar to the one described by rugbybloke:
    I have wrote 3 subroutines, one for peripheral-to-memory, one for memeory-to-peripheral, another for memory-to-memory. If I only call a single subroutine in the main function, ereryone will work properly; but when I call them in a queue, with ioctl to switch among them, bugs emerging.
    For example: (the three mode will be abbreviated as P2M,M2P,M2M)
    When I call those 3 routines in cycle with P2M the first:
    P2M(1)--->M2P(1)--->M2M(1)--->P2M(2)--->M2P(2)---->M2M(2)--->.........
    Then the first one---P2M(1) will work properly, when it turns to M2P(1), it will do the work of P2M with the inverse destination address and start address that assigned to M2P(1);M2M will do the work of M2P(1),P2M(2) do the work of M2M(1).........It seems that the next routine will do the work of the previous one, but the addresses of P and M are its own.
    I do not know whether I have described clearly. I will attach my code here, anyone who interest in it can test it on your board.
    Note:
    1: copy_1_to_range is just the P2M, range_to_1 is M2P and range_to_range is M2M.
    2: Here, I use SRAM as the test memory and SDRAM as the data and program memory. And also I use a fixed
    memory cell in SRAM as the peripheral. The base address of SRAM is 0x00800000.
    3: To anyone who has good ideas and advices for my program, I&#39;d like to receive your email to talk about
    DMA or anything else about NiosII. My email is: RemyMartin@eyou.com
    ******# include <stdio.h># include <stddef.h># include <stdlib.h># include "sys/alt_dma.h"# include "alt_types.h"# include "altera_avalon_dma_regs.h"# include "altera_avalon_dma.h"# include "system.h"# include "string.h"
    /* The following routines is for transmintting & receiving callback routines */
    volatile alt_32 transmitdone=0;
    volatile alt_32 receivedone=0;
    void transmit_done()
    transmitdone=1;
    void receive_done()
    receivedone=1;
    /* The following routines is for 1-to-range processing. */
    void copy_1_to_range(const char* dma_name,
    void* start_addr, //Here,start_addr is the "1"
    void* desti_addr, //and desti_addr is the "range"
    alt_32 transfer_count,
    alt_32 transfer_mode)
    alt_32 flag;
    alt_dma_rxchan rxchan;
    if((rxchan=alt_dma_rxchan_open(dma_name))==NULL)
    printf("\n Failed to open receive channel(1-to-range)!\n");
    exit(1);
    alt_dma_rxchan_ioctl(rxchan,transfer_mode,NULL);
    alt_dma_rxchan_ioctl(rxchan,ALT_DMA_TX_STREAM_ON,start_addr);
    if((flag=alt_dma_rxchan_prepare(rxchan,desti_addr,transfer_count,receive_done,NU
    LL))<0)
    printf("\n Failed to post receive request(1-to-range)!\n");
    exit(1);
    while(!receivedone);
    receivedone=0;
    alt_dma_rxchan_ioctl(rxchan,ALT_DMA_TX_STREAM_OFF,NULL);
    alt_dma_rxchan_close(rxchan);
    /* The following routines is for range-to-1 processing. */
    void copy_range_to_1(const char* dma_name,
    void* start_addr, //Here,start_addr is the "range"
    void* desti_addr, //and desti_addr is the "1"
    alt_32 flag;
    alt_dma_txchan txchan;
    if((txchan=alt_dma_txchan_open(dma_name))==NULL)
    printf("\n Failed to open transmit channel(range-to-1)!\n");
    exit(1);
    alt_dma_txchan_ioctl(txchan,transfer_mode,NULL);
    alt_dma_txchan_ioctl(txchan,ALT_DMA_RX_STREAM_ON,start_addr);
    if((flag=alt_dma_txchan_send(txchan,desti_addr,transfer_count,transmit_done,NULL
    ))<0)
    printf("\n Failed to post transmit request(range-to-1)!\n");
    exit(1);
    while(!transmitdone);
    transmitdone=0;
    alt_dma_txchan_ioctl(txchan,ALT_DMA_RX_STREAM_OFF,NULL);
    //alt_dma_txchan_close(txchan);
    /* The following routines is for range-to-range processing. */
    void copy_range_to_range(const char* dma_name,
    void* start_addr,
    void* desti_addr,
    alt_32 flag;
    /* Creat the transmit channel */
    printf("\n Failed to open transmit channel(range-to-range)!\n");
    exit(1);
    /* Creat the receive channel */
    printf("\n Failed to open receive channel(range-to-range)\n");
    exit(1);
    /* Post the transmit request */
    if((flag=alt_dma_txchan_send(txchan,start_addr,transfer_count,transmit_done,NULL
    ))<0)
    printf("\n Failed to post transmit request, the reason is %i\n",flag);
    exit(1);
    /* Post the receive request */
    LL))<0)
    printf("\n Failed to post receive request, the reason is %i\n",flag);
    exit(1);
    while(!(transmitdone & receivedone));
    transmitdone=0;
    receivedone=0;
    /* The main routine */
    main()
    char* name="/dev/dma_no1";
    while(1){
    copy_1_to_range(name,
    (void*)0x00800000,
    (void*)0x00800010,
    8,
    ALT_DMA_SET_MODE_8);
    copy_range_to_1(name,
    (void*)0x00800020,
    (void*)0x00800030,
    12,
    ALT_DMA_SET_MODE_32);
    copy_range_to_range(name,
    (void*)0x00800040,
    (void*)0x00800050,
    16,
    ALT_DMA_SET_MODE_8);}
    The receive and transmit are rather complexing in Nios II.
    As for the alt_dma_txchan_...and alt_dma_rxchan_....., the memory is the reference, that means: if u use alt_dma_txchan, the the memory is the transmitting one; if u use alt_dma_rxchan, the the memory is the receiving one.
    But when it turns to the parameters of ioctl, the meaning is the reverse: ALT_DMA_TX_STREAM means the peripheral will do the stream transmitting work, so does the ALT_DMA_RX-STREAM.
    It pained me so much when I use ALT_DMA_TX_STREAM_ON/OFF in alt_dma_rxchan_ioctl().
    I have not fully understand the alt_avalon_dma_launch_bidir/txonly/rxonly yet, it&#39;s rather confusing.
    In Nios I, the programming of DMA is rather easy, only copy_1_to_range(),copy_range_to_1() and copy_range_to_range() will do almost all the work!
    It&#39;s unfortunate, but it&#39;s true. The HAL DMA interface is much more complicated than the old Nios I example functions. There&#39;s two reasons for this:
    1. The HAL uses a callback interface rather than blocking waiting for the DMA to complete. This allows the processor to continue execution and do something useful while a DMA is underway - this is after all the reason for using a DMA rather than memcpy().
    2. A DMA process is described in terms of two half DMA&#39;s. While this is a little unatural when looking at the altera_avalon_dma component, it provides a much more general infrastructure which should be able to support future DMA controllers.
    To solve your particular problem, I&#39;d recommend providing a seperate DMA device for each peripheral you wish to communicate with - so in your case you&#39;d have three channels. That way you only call the ioctl at most once for each channel, and you avoid this problem.
    Even if the bug was not there, I believe you&#39;d find that this becomes necessary in any case once you start putting together a real system. Given that all the transfers are being processed in parallel to you main code execution, you&#39;ll find that it becomes difficult to synchronise the DMA activity so that you call the ioctls at the right time.
    You&#39;ll also have the problem of figuring out where incoming packets have come from. This way it&#39;s easy in that there&#39;s a one to one correspondance between DMA channel and source.
    I hope that makes sense, and solves your problem.
    Thank you.
    But by now, I am working for a new DMA driver which is more suitable for my project. Although @ltera will fix this problem soon, I think it&#39;s a good and useful experience which will give me a indepth view into
    the DMA, after all DMA will be used extensively in my project.
