15 years agoNIOS II Debugger Error
I'm using the NIOS II IDE version 9.0 SP2. My design includes a NIOS II processor with the JTAG Debug Module set to Level 1. I've build the design and programmed the corresponding .pof file into the ...
15 years agoHi,
I have the same problem with my custom board. I use quartus 9.1sp1. I have errors in my external sram : "Cannot insert breakpoint 3. Error accessing memory address 0x2205730: Unknown error 4294967295." Or "symbol is not available", Or watchdog timeout in debug mode : "Execution is suspended because of error. Watchdog has expired. Target detached.". Did you find the cause of your problems ? How do you fix it ? Thanks for you help.
