15 years agoNIOS II Debugger Error
I'm using the NIOS II IDE version 9.0 SP2. My design includes a NIOS II processor with the JTAG Debug Module set to Level 1. I've build the design and programmed the corresponding .pof file into the ...
15 years agoError accessing memory address 0x16714: Unknown error 4294967295. What resides at the above address (0x16714)? If it's flash, you won't be able to set a break point there without adding "hardware breakpoints" to your Nios II CPU and re-building in SoPC Builder. Otherwise...I dunno. Cheers, --slacker
