21 years agoNios-II core reset
I want to reset the cpu core without resetting the entire system module -- can anyone suggest a good approach? The application is to hold the cpu in reset while an external avalon bus maste...
21 years ago> However, I do like the idea of having a seperate reset for the NIOS II core ...
Agreed ... and I don't think this is unreasonable. For example, many DSP architectures have this feature (being able to hold the core in reset while an external master or 'host' initializes memory). I tried creating two system modules: one with the n2 core (and a few periperals), the other with my sdram and flash. The n2 core module and a PCI interface have master interfaces to the memory module. All modules were tied to hardware reset, however a reset signal from the PCI module (not the PCI reset) could also reset the core module ... but I'm having some troubles with this. (And I did gate the read/write signals from the core module when the PCI controlled reset is asserted). Anyway, I wanted to investigate the avalon resetrequest signal but I didn't see it show up when adding IUL in SOPC builder -- I guess I should check how the watchdog does it. BTW: does the watchdog reset the entire system module (SDRAM controller et. al.) or just the core itself? --Scott
