21 years agoNios II core minimal frequency?
Hi, are there any constrains for system clock. I'm interested in lower freq. than default value 50MHz. When I tried lower freq. (1MHz ! ) JTAG UART terminal was not correct. Is N...
15 years ago --- Quote Start --- hi all anyone has the answer to Fabio question? thanks Ale. --- Quote End --- I think the FPGA is static, at least within the range of clock values that I experimented with recently. My Cyclone III NIOS design uses a 100 MHz system clock. I varied the system clock in modest increments between 100MHz and 1MHz to test the power average draw as a function of frequency. My design worked without changes in that range. I didn't test the JTAG UART as my tests were all in standalone mode. JJS
