17 years agoNIOS II Command Shell
How to program/download .flash file into flash memory using NIOS II 9.0 Command Shell with serial cable?
17 years agoWhat is need to type in to IDE command shell to download the flash file to my flash memory. I had tried nios2_flash_programmer, but it says command not found. Is there an example to run like "Hello World"?
[NiosII EDS]? ....... nios2-flash-programmer..... Can the flash file be download with the use of serial port rather through the USB Blaster cable? I had tried using flash programmer in the IDE with just the .flash file into flash memory, but it does seem to work. What option should be used for .flash file into flash memory? It would be helpful if I have the ability to download using Nios II Command Shell and using Nios II IDE methods.
