rMa1
5 years agoNIOS II Command Shell can not work
I am using Quartus Pro 20.2, I want to download elf by NIOS II Command Shell, but I can not open NIOS II Command Shell, How should I do now? I install Quartus in the Windows OS.
EricMunYew_C_Intel
5 years agoCan you follow below to install:
1. install WSL for windows
i. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii5v2gen2.pdf (chapter 2.1)
Note: Windows 10 build version 16215.0 or higher is the recommended operating system version.
ii. After installation has successfully completed, launch Ubuntu 18.04.
iii. Install additional distro packages required for Nios II EDS using the following commands:
a. sudo apt-get update
b. sudo apt install wsl
c. sudo apt install dos2unix
d. sudo apt install make
2. install nios2 eclipse folder
