JBlec2
7 years agoNios II Code comparing with Hardware Code
Hi , i have a little Algorithm written for my NIOS II . And it works . I recently tested it. Now i want to implement this algorithm on my FPGA with system Verilog and also compare the speed. So first...
JBlec2
7 years agohi , thank you for your answer ! yes it would be good to see how the hls converts my C Algorithm into Verilog. But i also translated it by myself. Maybe not totaly correct. So this tool will help me a lot ! But i think i also need to implement my Verilog code with the Component Editor or something else. Because i want both , my NIosII with the C algorithm and my Verilog Harwdware on the FPGA in parallel. For testing i will input something first into my NiosII code and measure the time. After this i send data to my Algorithm Hardware and also measure the time . then i can compare the time. So no big thing i think.
But i want to do it this week :P
maybe someone else has an idea.
