16 years agoNIOS II byte enables?
I have a nios II system and some custom slaves. I understand that the Nios II address space is mapped to 32 bit wide registers. When I make readdata or writedata in my slaves 8 or 16 bits the CPU e...
16 years agohave a look at these IORD_8DIRECT or IOWR.... with 8 16 or 32 bit commands
if you use these instead of memory pointers with a 8 bit slave for example then only 8 or 16 bit are written and not 32 bit ....
