15 years agoNios II Burst Questions
Hi all, I need some help regarding bursts. First of all, I have designed a custom Avalon peripheral which acts like a bridge between Avalon and a custom DDR controller. The custom DDR controller a...
15 years agoWith old memory technologies (I can't remember whether it changed for SDRAM or DDR) processors used to read cache lines using an 8 word burst that started with the word they wanted - rather than the first word of the cache line (doing CAS only memory cycles while holding RAS asserted).
This gives lower memory latency. Modern memories directly support sequential burst access - but these won't wrap - so the burst must finish at the end of the cache line. I suspect bursts can start mid burst/cache line, so the cpu could still read the requested word first by doing two memory bursts. OTOH I went out of my way to use only tightly coupled memory and disabled both the instruction and data caches!
