MMuth8
6 years agoNIOS II Booting methods for MAX10 FPGA
Hi, We are using MAX10 FPGA and NIOS II processor. We have on board FLASH MEMORY(NOT QSPI), and nios code will be placed in the same. We need that the NIOS to be booted from on board flash, Is it po...
EricMunYew_C_Intel
6 years agoHi, Mahalakshmi
You can boot Nios II with MAX10 FPGA from an external parallel flash.
You may try 19.2 or later.
You may refer to below for the implementation:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_avalon_tc.pdf
By the way, can we close it if you have no more inquiry ?
Eric
praveenkumar
5 years agocan anybody help me the cfi parallel flash using generic tri state controller
