21 years agoNios-II boot monitor (u-boot)
Updated binary/source available at:
http://www.psyent.com/download (http://www.psyent.com/download) u-boot for Nios-II now includes support for the EPCS controller core. Try 'help epcs'. Support includes: - Device identification - Read to memory - Write from memory - Verify from memory - Protection control u-boot for Nios-II now supports the following filesystems: - JFFS2 - CRAMFS - FAT (12/16/32) Access to the Altera devkit CompactFlash in TrueIDE mode is also supported. However, unlike Nios-32, the Nios-II examples do not have CompactFlash support in the system module -- so you'll have to add it in yourself. You'll also have to configure and rebuild the u-boot sources to enable IDE/FAT support (IDE/FAT is not included in the new pre-built binary): In include/configs/PK1C20.h add the following to the CONFIG_COMMANDS macro: CFG_CMD_FAT and CFG_CMD_IDE. JFFS/CRAMFS is included in the pre-built binary. Two partitions are defined: 0 : 0x0020_0000 (2MB) -- for linux kernel 1 : 0x0080_0000 (1MB) -- sram for testing JFFS/CRAMFS images Use the chpart command to select the active partition. u-boot will automatically detect cramfs/jffs2. If you have problems or questions, please let me know. Enjoy. Regards, --ScottNo RepliesBe the first to reply
