17 years agonios II boot loader
Hi.
when I use FPGA desgin a NIOS II system,I meet a program. It described as follow: my system has a external 256K 16-bit SRAM, one Serial controller, one epcs controller 4K onchip_ram and 1K onchip_rom. Hardware config data and software program are boot load by EPCS. And SOPC CPU's Reset Vector:epcs_controller offset:0x0. Exception Vector:onchip_RAM offset:0x20. when NIOS II IDE System Library set as: .text ext_ram .rodata ext_ram .rodata ext_ram The system boot success,but the program does not run. but when NIOS II IDE System Library set as: .text onchip_ram .rodata ext_ram .rodata ext_ram The system boot success,but the program run. Please give a suggestion what should I do? is there anything worng with my system? Sorry for my English. Thank you. PS: my software verion is Q-II 7.2 SP3.1 Reply
Run a memory test on your external SRAM. There is a memory test software example in the Nios IDE
