12 years agoNios II basic
Hi, I am a beginner .I am using Nios II development kit stratix II Ep2s60f672c3n. In the flash memory of board contains nios file.while power on file transfer to fpga... It means can I direct...
12 years agoU have to build the FPGA system using SOPC/QSYS , the NIOS code to interact with the FPGA will have to be done using eclipse
for ex : to transfer data from NIOS Console to DDR. U will have to create a system onchipmemory-DDR controller-DMA etc using SOPC/QSYS and synthesize to get an .sof then ur code to sent data to the write /read to the DDR will be a .c file which you have to build using eclipse and get an .elf U can flash both .sof n .elf and they would do the respective work.
