22 years agoNIOS II Assembler example?
I am kind of stuck with my board working quite fine under debugger and not working full speed, standalone and I am searching for other options to troubleshoot... One idea I have is to write a l...
22 years ago1. I started with assembly language by first creating a simple C Project,
e.g. "Hello Led" 2. I set compiler flag --save-temps 3. I added a new C file "sample1.c" to the project,e.g with following code and called the function from the main loop ... void sample1(void) { int i; i = 0; while (i<200000) { i++; } } 4. you can now check under Debug/sample1.s the generated assemply language 5. I then added a file "test.S" (remark upper'S') to the project. .file "test.S" .section .text .align 3 .global samplefunction .type samplefunction,@function samplefunction: addi sp, sp, -48 stw r16, 36(sp) stw r17, 32(sp) stw r18, 28(sp) stw r19, 24(sp) stw r20, 20(sp) stw r21, 16(sp) stw r22, 12(sp) stw r23, 8(sp) stw fp, 4(sp) stw ra, 0(sp) # here we start .. some usefull code ldw r16, 36(sp) ldw r17, 32(sp) ldw r18, 28(sp) ldw r19, 24(sp) ldw r20, 20(sp) ldw r21, 16(sp) ldw r22, 12(sp) ldw r23, 8(sp) ldw fp, 4(sp) ldw ea, 0(sp) addi sp, sp, 48 ret 6. I added a call to samplefunction() in the main loop The file should compile normal, it should generate a file DEBUG/test.s and DEBUG/obj/test.o, the last is important for debugging assembler debugging: the problem seams to be that the assembly routines are not shown in the Outline Window. the only trick I found, is the following 1. switch to C/C++ Development Perspective 2. in C/C++ Projects go to yourProject/Debug/obj/yourAssemblerFile.o You should see there your assembly subroutines with a green point in front Right Click the function you want to debug, and click "Add/Remove Breakpoint" 3. Switch back to Debug Perspective, and check under Breakpoints, if your breakpoint was set. start your program, it should now stop at the beginning of your assembler function, showing the assembly instructions. Remark: Perhaps you must already check under "Windows->Preferences->C/C++->Debug" "Automatically switch to dissassembly mode" hope this helps
