Nios II Application and BSP template creation error
Hi, Kyle
Is your problem resolved ?
Can I close this if you have no more inquiry ?
Eric
Hi Eric,
I have the same issue, which I can't create the app and bsp from the eclipse menu.
I use Quartus 19.1 standard edition. All the issues started while my Win10 an automatically update.
Before the update I worked with wsl1 and all was fine, currently had to upgrade to wsl2.
I uninstalled and install the Quartus and the Eclipse all by the book. Did all the recommendation you posted (except the: https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/embedded/2019/error--failed-to-execute--wsl---create-this-bsp-no-make.html, which will be very helpful of you can explain how the NIOS command shell should replace the BSP and application generation).
I see in other posts that this is common problem.
I'll be glad if you can instruct how to return the Eclipse back to work.
Thanks, Alon.
