20 years agoNios II and separate WRITE_N signal to CFI Flash
Hi, It has been long time I played with Nios II, my first attempts were abandoned due to the project change. Now I am blessed with another project which would have a Nios II as a CPU candidate and...
20 years agoBy the way, my problem turned out to be unrelated to the separate write_n signal. It appears that it's not possible to use the CFI flash drived when "Reduced device drivers" is set in the System Library properties.
