20 years agoNios II and separate WRITE_N signal to CFI Flash
Hi, It has been long time I played with Nios II, my first attempts were abandoned due to the project change. Now I am blessed with another project which would have a Nios II as a CPU candidate and...
20 years ago --- Quote Start --- originally posted by pszemol@Mar 12 2006, 05:35 PM thank you luca, this is very good observation! http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
i wonder now if this is just a bug, or intentional...
anyway, i have modified ptf file to correct write_n signal
and we will see how long my change will stay there...
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13346)
--- quote end ---
--- Quote End --- No bug: if you specify shared you get a signal with the name of the bus, if you specify not shared you get individual signal for each peripheral, using both you get both ptf manual editing is not reccomended if you are not familiar with it, anyway the modification will remain also after SOPC generation and regeneration, unless you delete the component
