21 years agoNios II and Hardware/Software co-simulation
Hello, I am interested in comparing the performance of the Nios II processor, with and without a custom instruction that I have developed, when running some benchmarking software algorithms. ...
21 years agoModelsim provides 100% accurate results for the processor performance. If you are interested in measuring performance with and without custom instructions this should suffice. Notice that I didn't say you have 100% accurate system performance since the DRAM models included with the kit are not cycle-accurate. This only affects your performance if your program has a high DRAM bandwidth.
If you are using Nios II IDE, make sure you check the box on the system libraries project page to compile for modelsim.
