21 years agoNIOS II and ASMI
Folks, Why is the ASMI interface considered a "legacy" peripheral in NIOS II when it has a set of functions in the NIOS II kit? Is anybody using this component with success in NIOS II?
21 years agoHi Edward,
>Did you roll your own because you could not get the supplied functions working? No ... I never tried the supplied functions. I implemented the interface as part of u-boot with Nios-32 ... before the IDE, and epcs programming via JTAG, etc. etc. So I just brought the code forward and continue to use it with Nios-II. And, as you may have detected ... it bothers me when I'm told I "must" use vendor-supplied drivers ... I've been burned too many times 8-( > There are no examples and I cant seem to get the library to link in. If it's any help, you can download the u-boot code and see cpu/nios2/epcs.c: http://www.psyent.com/download (http://www.psyent.com/download) Regards, --Scott
