22 years agoNios II Advanced C/C++ project
Hello, I am new to this forum and new to NIOS II. I started with some simple application on the NIOS II using the Eclipse IDE. Everything worked fine so far. Now I tried to includee some sha...
22 years agoHi Dave,
I got it working, but however , I spend some time to think why there is only the possibility to put thinks in subdirectories. The solution seems to be that you always work with CVS. Therefore you just have a working copy of "common" in each subdirectory. It is, even in this configuration, not the right structure but a way to do. Regards Reinhard
