19 years agoNIOS II addressing problem
I am having trouble with an SOPC builder component. I am using signaltap to try to debug it. I have a pointer to an address which I write to and then read from. But the address that is asserted is...
19 years agoThanks for the reply.
I am looking at both the address coming from the NIOS and going to my peripheral. I have taken into account the bus-matching. Also I have no data cache. I have set up a simple component which passes through the NIOS cs, data, address lines. I have captured a read cycle in signaltap and can see that a read takes 2 clock cycles and half way through the lsb address latches through.
