19 years agoNIOS II addressing problem
I am having trouble with an SOPC builder component. I am using signaltap to try to debug it. I have a pointer to an address which I write to and then read from. But the address that is asserted is...
19 years agoIf you are looking at the address coming from Nios, remember that the databus is 32-bits wide. Assuming your peripheral is 16-bits wide, the Avalon Switch Fabric is taking care of the bus-width matching for you. Therefore, if you really want to see the low order address bits, you'll be better off examining the address at the peripheral.
BTW, I assume you have no data cache in your system. Otherwise, these accesses will be cached, and the accesses won't make it to your peripheral as anticipated. --- Quote Start --- originally posted by richy759@Dec 8 2006, 09:30 AM this is not the case however. address bit 1 is 1 when i do a write but when i read, address 1 is 0.bearing in mind these are the nios address lines and not mine.
has anyone come across this before or have any idea what the problem may be?
many thanks,
richard
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19907)
--- quote end ---
--- Quote End ---
