15 years agoNios-II Address Bus XXXXXXXX normal?
About 5 cycles after reset has gone inactive, the Nios-II CPU drives 'X's (yes they are true X's, which typically means two signals are driving each other) onto the address and byte enable buses. Thi...
15 years agoDo you use a synchronized reset that is active for ~100ms (100 ms in order to make sure it reaches the entire board) ? I use the
http://datasheets.maxim-ic.com/en/ds/max823-max825z.pdf IC, combined with VHDL code to make it synchronized. I use the NIOS II with Quartus 10.1 and I have no problems, but I'm no expert.
