21 years agoNIOS II 5.0 and new format of .cdtbuild ?
Hi everybody,
I try to recompile LWIP Standalone v0.7.1 with the new NIOS II v5.0 IDE and when I try to open the template (file -> new project -> new C++ application), the assitant send to me an error message that the new IDE doesn't know the format of the .cdtbuild file in the LWIP template. Do you have any suggestion about this problem ? Thanks, Etienne1 Reply
I had too had this problem and found this in a lwip readme.txt: .cdtbuild: Eclipse plugin default build file. Normally generated, but included here to provide the default compiler include PATHs. If the example will not build with this file, remove it, and add the following "Include Paths" to the nios-elf-gcc general configuration options (available in the "Properties" of the sample project): ../lwip-0.7.1/src/include ../lwip-0.7.1/src/include/ipv4 ../lwip4hal/include ../apps Deleting .cdtbuild from altera\kits\nios2\examples\software\lwip_web_server\ seems to do the trick. Regards, Aidan
