15 years agoNIOS II 11.0--Error creating project
I am new to NIOS. I have build an SOPC system using Quartus 11.0. The system has an on-chip ram. Now, I am using NIOS II - Eclipse platform to build the application. I choose "New NIOS II Application and BSP from template". After adding my SOPC Information file, I selected blank project, but when I try to create the project, it gives the following error.
Quote: SEVERE: [Error] altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.entry, .exceptions, .rodata, .rwdata, .text, .bss, .heap, .stack]" SEVERE: [Error] altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.entry, .exceptions, .rodata, .rwdata, .text, .bss, .heap, .stack]" SEVERE: nios2-bsp-create-settings failed. nios2-bsp: nios2-bsp-create-settings failed nios2-bsp hal . D:/***.sopcinfo --cpu-name cpu failed Can somebody help me with this? Is this error caused by some problem with my SOPC system or there is some other reason. I am using NIOS II EDS 11.0. Any response is highly appreciated. ---------------------------6 Replies
I have the same problem...
Can anyone help us? - Altera_Forum
I'm using BeMicro SDK board and I have exactly same problem but I could not find a solution yet. Thanks.
Hi, when generating the BSP, try this:
in BSP editor-> liker script sheet assign linker region name to the desired sections. The .entry and .exception are set from SOPC/QSYS. I hope that was helpful. - Altera_Forum
it works... - Altera_Forum
--- Quote Start --- Hi, when generating the BSP, try this: in BSP editor-> liker script sheet assign linker region name to the desired sections. The .entry and .exception are set from SOPC/QSYS. I hope that was helpful. --- Quote End --- Hey, Can you please explain what do you mean by ".entry and .exception are set from sopc/qsys". When I am in BSP editor-> linker script Tab, I cannot select .entry and .exception options. Please let me know if I am doing something wrong or I am missing something. Thanks. - Altera_Forum
Hi, exactly my point.
You can modify those field from SOPC/QSYS only. https://www.alteraforum.com/forum/attachment.php?attachmentid=8394
