16 years agoNios II - Eclipse 9.1 quits when I try to make a new Hardware Run Configuration?
Hi, I imported my first project in the Nios II 9.1 Eclipse Platform. It compiles inside the Eclipse GUI, but when I go to create a Hardware configuration the program simply quits without any error...
16 years agoThank you for the link, I am sure it will come in handy..
I was just about to reply to my own post. It appears that if you use -O3 on you BSP it causes this behavior. I was randomly trying things and selected -O2 now the window opens and I can start editing the Run configuration but in the Project name: pull down for the Nios II hardware configuration my application project doesn't show up? Only my library project shows up.... So I am off randomly trying things again. Suggestions?
