21 years agoNios IDE supports SSH2 ?
I want to use the NIOS IDE CVS support to maintain my source codes.
But it seems that it only support SSH (and not SSH2) cnnection. Since our CVS server only supports SSH2, I can not use the NIOS IDE CVS support. The Eclipse 3.0 environment does support both SSH and SSH2 connections. Any ony helps?? Does any one know if there is a SSH2 CVS plug-in for NIOS IDE???? Thanks in advance! Regards, Kwok Wong1 Reply
--- Quote Start --- originally posted by kwokwong@Oct 13 2004, 10:08 AM i want to use the nios ide cvs support to maintain my source codes.but it seems that it only support ssh (and not ssh2) cnnection.
since our cvs server only supports ssh2, i can not use the nios ide cvs support.
the eclipse 3.0 environment does support both ssh and ssh2 connections.
any ony helps??
does any one know if there is a ssh2 cvs plug-in for nios ide????
thanks in advance!
regards,
kwok wong --- Quote End --- [Solved] I find this plugin: http://www.jcraft.com/eclipse-cvsssh2/ (http://www.jcraft.com/eclipse-cvsssh2/) It works for me!
