14 years agoNIOS IDE SOPC design
Sir, i hv created a SOPC design nios system using nios II (s) , jtag, sdram(16 bit 8MB) ,two 8 bit pios(Switches & LEDs ),timer,pll megafunction using Quartus 7.2 and successfully run hello p...
14 years agoSir,
Thanks for the reply , I'll try soln given by you.in ur post Shoulld i read poc as pof and tsa as tse Recently, I tried using nios II (s) , jtag, sdram(16 bit 8M ,two 8 bit pios(Switches & LEDs ),timer,pll megafunction,added flash using Quartus 12.0 and successfully run hello program a on this design using Nios IDE 12.0 using CycloneII EP2C35F672C6ES Altera's DE2 board. However for SSS gives following error Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prepped 0 interfaces, initializing... inet startup error: unable to find any working interfaces panic: IP dtrap - needs breakpoint gone thru similar threads but cud not figure out soln kindly help Thx
