14 years agoNIOS IDE SOPC design
Sir, i hv created a SOPC design nios system using nios II (s) , jtag, sdram(16 bit 8MB) ,two 8 bit pios(Switches & LEDs ),timer,pll megafunction using Quartus 7.2 and successfully run hello p...
14 years agoInstead of generating the poc file, try with a script file from Nios shell, similar to the one I recently posted in this thread:
http://www.alteraforum.com/forum/showthread.php?t=36728 (you'll have to change from epcs to cfi flash...) Regarding Nichestack, you get a warning during compilation but this will not affect the generated code. You should be able to run the project for evaluation purposes even without a licence. I'd suggest Quartus v9.0 sp2, since I've used it with Nichestack and tsa, although with a EP3C device.
