14 years agoNIOS IDE SOPC design
Sir, i hv created a SOPC design nios system using nios II (s) , jtag, sdram(16 bit 8MB) ,two 8 bit pios(Switches & LEDs ),timer,pll megafunction using Quartus 7.2 and successfully run hello p...
14 years agoSir,
I have corrected this error by renaming pio and adding ext_flash(flash cfi)in SOPC However compiling the above design for SSS gives message that current license does not support Nichestack Is there any soln for this problem? I also tried Flash programming with 7.2 but it is not generating pof file i tried Flash progrmng with 12.0 , it says it does not support my device Cud you suggest the right Quartus II software version for my device (CycloneII EP2C35F672C6ES Altera's DE2 board) and application(i require to use Nichestack , Socket programming and TSE ) and how do i get the license for the same Regards,
