20 years agoNIOS IDE and makefile problems kill me.
hi :)
sorry for my poor eng. I'm kor. student and trying to compile h.264 decoder (jm86.zip) for NIOS II, using NIOS IDE tool but I faced big fat desperate problem. I have makefile( for.. might be for i386??) and all the source code and *.h files, but I cannot compile it for NIOS II by using NIOS IDE!!! you know I have to compile the source files via NIOS IDE to make it work. So... anyone have any idea?? how can I open the makefile(I aleady have)? how can I cross-compile it? I have makefile like this.#### ## Makefile for H.26L encoder# ### ## generated for UNIX/LINUX environments# ## by H. Schwarz# ##
NAME= ldecod
# ## include debug information: 1=yes, 0=no# DBG= 0
DEPEND= dependencies
BINDIR= ../bin
INCDIR= inc
SRCDIR= src
OBJDIR= obj
ADDSRCDIR= ../lcommon/src
ADDINCDIR= ../lcommon/inc
CC= $(shell which gcc)
LIBS= -lm
FLAGS= -ffloat-store -Wall -I$(INCDIR) -I$(ADDINCDIR)
ifdef DBG
SUFFIX= .dbg
FLAGS+= -g
else
SUFFIX=
FLAGS+= -O2
endif
OBJSUF= .o$(SUFFIX)
SRC= $(wildcard $(SRCDIR)/*.c)
ADDSRC= $(wildcard $(ADDSRCDIR)/*.c)
OBJ= $(SRC:$(SRCDIR)/%.c=$(OBJDIR)/%.o$(SUFFIX)) $(ADDSRC:$(ADDSRCDIR)/%.c=$(OBJDIR)/%.o$(SUFFIX))
BIN= $(BINDIR)/$(NAME)$(SUFFIX).exe
default: depend bin tags
dependencies:
@echo "" >dependencies
clean:
@echo remove all objects
@rm -f $(OBJDIR)/*
tags:
@echo update tag table
@ctags inc/*.h src/*.c
bin: $(OBJ)
@echo
@echo 'creating binary "$(BIN)"'
@$(CC) -o $(BIN) $(OBJ) $(LIBS)
@echo '... done'
@echo
depend:
@echo
@echo 'checking dependencies'
@$(SHELL) -ec '$(CC) -MM $(CFLAGS) -I$(INCDIR) -I$(ADDINCDIR) $(SRC) $(ADDSRC)
| sed '\''s@\(.*\)\.o@$(OBJDIR)/\1.o$(SUFFIX):@g'\''
>$(DEPEND)'
@echo
$(OBJDIR)/%.o$(SUFFIX): $(SRCDIR)/%.c
@echo 'compiling object file "$@" ...'
@$(CC) -c -o $@ $(FLAGS) $<
$(OBJDIR)/%.o$(SUFFIX): $(ADDSRCDIR)/%.c
include $(DEPEND) and I have all the source files. http://ftp3.itu.ch/av-arch/jvt-site/ (http://ftp3.itu.ch/av-arch/jvt-site/) here. reference_software/jm86.zip plz help me save me I'm about to die... :(1 Reply
your program need os support.
you may try uClinux. http://nioswiki.jot.com/%c2%b5clinux (http://nioswiki.jot.com/%c2%b5clinux) it is easy to run makefile. CC = nios2-linux-uclibc-gcc unzip -a jm86.zip but your codes are not clean for gcc. it seems they are for vc. (bad coding style). global are mixed up in global.h , they should be extern .
