Nir_Zilkha
2 years agoNIOS IDE - Link file to project
Hello Im using Eclipse IDE version Indigo Services Release 2 I have an existing project in which all the files are within the project directory. I've moved the files into a new folder (outside...
wwanalim_intel
Contributor
2 years agoBased on the content, I think it is explaining Eclipse (GUI-based) and User (CLI-based) source management.
By default, all projects start with Eclipse (GUI-based) source management.
Remove from Nios II build & Add to Nios II build are available in Eclipse (GUI-based) source management only.
If it is in user source management, they are turned off.
I believe after linking resource, user needs to Add to Nios II build to trigger the Makefile update.
It is not done automatically based on the white/green dot indicator.
Thank you.
Fathulnaim
