Nir_Zilkha
2 years agoNIOS IDE - Link file to project
Hello Im using Eclipse IDE version Indigo Services Release 2 I have an existing project in which all the files are within the project directory. I've moved the files into a new folder (outside...
wwanalim_intel
Contributor
2 years agoHi,
Can you check if you followed the same procedure as below.
The Sopc Design File (.sopcinfo) path is stored as an absolute path instead of relative path. To import Nios II Eclipse project from a different location you may follow the steps below:-
How to import a Nios II Eclipse project (Application and BSP)
- Go to Start -> launch “Nios II <version> Software Build Tools for Eclipse”-> specify your current workspace directory.
- Go to File -> Import -> select “Nios II Software Build tools Project” -> double click and select “Import Nios II software Build tools Project” -> click Next button.
- Browse for your project location -> select “software\<Application> Folder” -> Input the Project name: need to be same as the Application folder name -> Click Finish.
- Do step 3 above for the <BSP> Folder. Browse for your project location ->Select “software\<BSP> Folder” -> Input the Project name: need to be same as the BSP folder name -> Click Finish.
- Please make sure that the .sopcinfo file for the project is located in the same directory as set in your new project’s “software\<BSP> Folder\settings.bsp” : <SopcDesignFile>**the location of the .sopcinfo file**\*name*.sopcinfo</SopcDesignFile>
- Lastly, go to Project-> Build All; build the project to make sure the import action has been performed successfully.
Note: There is two important points that need to take care:
- The new Application and BSP “Project Name” must be the same as the original Application and BSP “Folder Name”.
- The .sopcinfo file location must the placing in the same directory as stated in new project’s “software\<BSP> Folder\settings.bsp”.
