21 years agoNios-I speed in QuartusII 5.0
Hi, I've just moved from Quartus 4.0 to Quartus 5.0, re-generated my Nios sub-system using SoPC Builder, and the run the Cyclone-based design through Quartus syhthesis and place & route. ...
21 years agoI've had the same problem
And i find solution using design compiler it try to implemend design several times and afters this design compiler save in project parameters for best fit. So - use design compiler in Q5 - it works
