21 years agoNios-I speed in QuartusII 5.0
Hi, I've just moved from Quartus 4.0 to Quartus 5.0, re-generated my Nios sub-system using SoPC Builder, and the run the Cyclone-based design through Quartus syhthesis and place & route. ...
21 years agoHi,
Yes, I posted this query on comp.arch.fpga also. Thanks for the suggestions but it's not a QuartusII-4.2/5.0 synthesis/fitting issue as such, it's something to do with the SoPC-Builder in 4.2 and/or 5.0. I don't have any problem importing the 4.0 database into 4.2 or 5.0 and running it through synthesis and fitting, when I do that the timing meets the 90Mhz target. However, if I re-generate the Nios sub-system using SoPC-Builder in 4.2 or 5.0 and run through synthesis/fitting, then the performance drops to around 70Mhz. If I was a cynic I would wonder whether Altera have made Nios-I slower in order to push people towards Nios-II :-) Alan
